b16a2 swap into 97 civic ex help NEEDED.
Discussion in 'Civic and del Sol - EG and EK' started by ilikevtec, Feb 4, 2011.
  1. ilikevtec
    ilikevtec New Member
    I found this site the other day and looks good. I am a rookie at all of this stuff. I know that I have the stock d16y8 in my car. I bought a b16a2 engine with the tranny. The guy I bought it from is a close friend and said it is the complete swap. I need help with steps on putting it in and wiring everything up. Taking out the d16 shouldn't be hard. If somebody could just give me some help on steps I need to do to put the engine and tranny in so there is vtec and it runs it would be great! Thanks.
  2. hondafreak513
    hondafreak513 New Member
    O hi O
    You will just need the rear T-bracket, driver side mount, both torque mounts for the front, Axles from the b16, shift linkage from a b-series, ecu for the b16. Vtec will plug right up..
  3. ilikevtec
    Wow thanks for replying so fast! Great thanks, and what about ecu stuff? What is that?
  4. hondafreak513
    O hi O
    You will need the P2T ecu but it is for the obd2b you have a obd2a plug I think there is a conversion harness to change it..
  5. ilikevtec
    Sweet thanks again. And after I take out the d16 i just pretty much bolt on the b16 and plug everything back up?
  6. hondafreak513
    O hi O
    As long as you have the b16 mounts, then yes it just bolts right in..
