b16a2 swap into my 2000...?
Discussion in 'HYBRID -> EG-EK / DC' started by jdm_coupe, Jan 22, 2005.
  1. jdm_coupe
    jdm_coupe Junior Member
    I am planning on purchasing a motor from this guy for a really good deal...
    2000 USDM b16 Swap. 60,xxx
    -engine,tranny
    -wiring harness un-cut
    -ecu,shifter linkage
    (no mounts or drive shafts)
    i have a 2000 coupe right now with a sohc...can i use my mounts and drive shafts now or no? do i need anything else additional to have this dropped in? OH and do i get to keep my ac and my power steering?
    thank you
  2. swanny
    swanny Senior Member
    buck teeth and government checks, PA
  3. civiclxb16
    civiclxb16 Senior Member
    Poconos pa
    no the mounts will not work (trust me i tried)lol. i have mounts for sale poly urethane filled pm me if you want them :thumbsup:
    NO you have to get 94-01 integra axles or 99-00 si axles and haft shaft make sure he gives you that at least if not local junk yards
    just the mounts and the radiator hoses some fresh oil and some fresh antifreeze you should be ok a large cup of coffee and lots of band aids
    all depends if he gives it to you or not!
