B16A2
victor5592001
Hi I wanted to add Turbo to my 99' honda civic si. It is going to be daily driven. And my goals are to push. 8 psi and every once boost it to 10-12 psi. I dont belive my comp ratio will let me run that. What kind of pistons would you guys recomend. also will a thicker gasket will help? I am just getting set up. I want to get a custom turbo. I am thinking on putting a T3 super 60. Do you guys recommed something better? I would appreciate your guy's help.
your compression ratio at 10.2-10.4:1 is a little high... but not bad.
tuned well, it will hold fine.
you're not going to be able to get above 10.65 psi, without the aid of a 3-bar map sensor, and a standalone to control it. so consider 10 your limit without hondata, or the likes.
