the block itself has a hole in it from when i bent a rod...
so this is only good if you want to resleeve a block...and its better to start with a b-series vtec block...as opposed to a b18b/a.
its complete, and it only has 20k original miles on it. the water pump feels excellent, and the oil pump is also excellent.
i was asking 150 as it is...and if nobody buys it i will part it out...
ie b16a crank
water pump
oil pump
oil pan
oil pickup
here are some pictures...
if i had time...i would send this block to golden eagle...then order eagle rods and endyn pistons which would make displacement around 1.9liters. however, i dont' have much room where i live so i'll be parting it out or selling it as a whole...
ie b16a crank
water pump
oil pump
oil pan
oil pickup
