93 sick civic
pmpjuce
Ok here it goes...
I have a 93 civic ex and took out my D16Z6, ECU, and wire harness... When the B16A3 harness was disconnected it was cut from the passenger side underneath on the passenger side fire wall. Where it was detached I started installing the wiring harness for the new B16A3 . So i'm pretty much trying to tie in a DOHC harness into a Sohc.
I started by taking out everything from the underside of the passenger side glove box for easy access.. Then I began removing the wires from the D16 harness, then crimped to the B16 harness one by one. I was hoping that the wires would have the same colors so I could just snip 'n crimp. I realize that the wires may not have the same color codes on them, but I started anyways.
Of the wires that are left, the colors somewhat match but the lines on the wires are not matching...
For instance a black wire with yellow lines, and silver stamp every other inch or so. Verses a black wire, yellow lines, but with 2 silver stamps every other inch... Or a solid baby blue wire, and the only other matching wire is blue w/ a yellow stripe. These are just a couple of them...
The wires that I have left alone do not match either of the colors on either end of the harness. I have a haynes manual for all SOHC 92-95 civic/ del sol models. But I have no idea what im looking at, and the diagrams are squares. I have not a clue how to interpret them. Not to mention I'm not using a sohc motor anymore. I guess what my question is, could I put the closest colors together? Probably not a smart idea, and thats why I'm here. If need be I'll type every wire I see. But I think thats a bit much. Help lol
