MaaseyRacer
The motor swap will be pretty straight forward. all you need is mounts, check the hasport swap outline:
http://hasport.com/Tech/Installs/Swap%20Ou...l%20bseries.htm
as far as auto to manual, you should go to a junk yard and get clutch hosing for fluid, clutch pedal, shift linkage, transmission housing, slave cylinder, and mounts. This is a list that a member name liquidblaze gaveme PM him and he will probably tell you more.
Good Luck...
Good Luck...
