93 sick civic
pmpjuce
Alright I finally rewired the harness and everything is plugged in... I tried starting it but no go, it wants to turn over but no ignition... I looked back under the hood for a problem and saw a connector looking for a home... Its located behind the block and branches off the loom under the intake manifold next to the firewall engine mount... If it helps, this B16A3 was running w/ a turbo, but not any more...
I don't know what the prob is but maybe its the connector not being fastened somewhere? Its the only connector hanging around... I could be wrong but maybe its the knock sensor I keep reading about??? I've been searching the forums about this, and if this is the prob where would I connect the sensor, and where would I pin it into the ecu???
Does anyone have an idea of what the prob may be? I'll give as much info I can to anyone who knows what I should be looking for... I've been on this project for a few months now and I'm almost done, any help would be awesome thanks.
