b16b obd
heunde
which obd has the ek9 engines obd2a or obd2b
and can i run the engine whit oem ek9 engine harness in my civic hb 99-00 90HP
civics 1996-1998 obd2-a
civic 1998-00 obd2-b
im confused by the rest of your post. I belive you want to use your stock harness?
If I understand you right, short answer yes you can
you will most likely have to add wires, what wires? you need to do a search.
96-98 is obd2a, 99-00 is obd2b. and no you cant use the harness.
