b16b or a into EK coupe 96 (d16y8 engine) - belts ???
loverboy
Hey guys !
My engine swap is going to be one from this 3 options :
1. b16b CTR.
2. b16a from civic SiR II.
3. b16a2 from civic Si.
Wich belts should i buy (timing,AC,power steering...) from which car that will fit the engines and my car?
Where can i buy these belts ?
Thanks
yes and you can buy them at any parts place but i would go with oem honda parts
Thanks for the help my friend!
I have one more qestion:
Usually a p/s pump comes With the new engine, but do i need to replace the p/s pressure line that goes from the top of the pump to the p/s rack ?
If i do need, which pressure line will fit ? the one from the same engine (b16b/a) that im using for the swap, or any pressure line from b16/18 will fit ?
Thanks.
