civickidHF
alright, the engines in, shift linkage shortened mounted up and all, BUT im stuck on wiring... i bought the ECU jumper harness and it came wirh 9 loose wires.... o2 sensor heater control (02 BLK wire), 02 sensor signal (02 WHT wire), VTEC sloenoid signal, VTEC pressure switch signal, Intake air bypass signal, knock sensor signal, Power (IAB,o2 BLK Wire), Ground (SCS,VTM,02 GRN Wire), and service check signal.... they all come with a color next to them.. but where does the wire go from the jumper harness?!?!
WIRE COLOR ITEM FUNCTION
blue P02SHTC 02 secsor heater signal
white PH02S 02 sensor signal
Violet VTS VTEC solenoid signal
grey VTM VTEC pressure switch signal
green IAB intake air bypass signal
orange KS knock sensor signal red IGP power (IAB,02 blk wire)
Black (l) PG Ground (scs,VTM,02 GN Wire)
Yellow SCS service check signal
this is what i have, the 9 colors are loose wires from the ECu jumper.. im not sure where they go.. can anyone PLEASE HELP
