B17 into ek
Discussion in 'HYBRID -> EG-EK / DC' started by Savage211, Jul 9, 2006.
  1. Savage211
    Savage211 Junior Member
    Hi,
    I know alot of people don't recommend it but i can get a killer deal on a b17 motor, then i'd buy a hydro tranny. So i was wondering that if i got everything from the swap minus tranny what else would i need.
    Like would i need b16 or b18 mounts?
    OBD2-OBD1 conversion harness?
    thanks and it would go into a 98 civic coupe.
  2. qtmac_mien
    qtmac_mien Senior Member
    what you will need:
    Mounts
    99-00 driver side motor mount bracket
    99-00 Rear "L" bracket
    the rest of the mounts and brackets will work
    Wireing
    use ur civic harness and modify it to fit (if u want it to look stock, take ur stock harness and rip off all the black stuff covering the wires and plug it all up on the b17...this way u dont have to cut and splice wires...now the wires that still dont reach, just cut, solder, and heatshrink...after ur done put all the black covering back on and use electrical tape and take it all back up nicely.)
    ECU
    if u wanna go obd1 then u would need a jumper harness from obd2a to obd1...if u just wanna keep it obd2 then find a obd2 ecu like a CTR or ITR and use that..
  3. Savage211
    Thanks so much man, thats exactly what i was looking for! :D
  4. killercannible
    killercannible Senior Member
    just a note, a us b17 is not really a 1.7 litre it is really just a b16 like those found in jdm da integras.
  5. Savage211
    interesting, so the piston diameter is the same as a b16?
  6. vanillakilla
    vanillakilla Senior Member
    Tacoma Washington
    all b series motors have the same piston diameter. the b17 gets its extra displacement from the crankshaft used
  7. Savage211
    no way, i never new that. Nice that at least on this forum people don't bash someone who's learning. :D So i could get a Type R crank and oversized itr pistons and have my block honed. Then i'd be set on the bottom end. Sweet.
  8. vanillakilla
    Tacoma Washington
    ummm if you put a type r crank in you would need custom rods and probably have to modify the block and crank. And you have to bore the block not hone it to fit oversized pistons
