b17 swap into da ls
Discussion in 'HYBRID -> ED-EF / DA' started by NJXFALLSXIN, Sep 4, 2009.
  1. NJXFALLSXIN
    NJXFALLSXIN New Member
    texas
    i have a chance of getting a b17a motor but before i do can anyone tell me what all i will need to swap it in my da it has a b18a1 now so help me please?
    is this motor even worth my attention to clean up back to oem then later bolt ons or boost?
  2. NJXFALLSXIN
    texas
    also can i throw the head on a b16 bottom?
  3. skellagher
    skellagher Elder Driver
    Newark, De
    if i am not mistake all a b17 is is a stroked b16 so im pretty sure the head is the same casting so i dont think there would be any benefit for you to swap the head on a smaller bottom end so stick with the b17 and i would use the 94-95 gsr ecu so u would need to go to obd1 which is not at all difficult the obd0 to obd1 harness should include wiring for the vtec. correct me if i am wrong on any of the above info
  4. skellagher
    Newark, De
    also i would use the stock b17 dizzy but if it doesnt have one just use b16
  5. skellagher
    Newark, De
    or better yet throw the b16 head on your ls thats always a fun swap.
