ok, i've got the engine in..and wired up as much as i know how...i used to 5 wire vx to 4 o2 article to wire my o2..and other than that i havent touched the wiring..i used my vx wiring harness..and the car cranks and runs..but its really rough..i need to know how to wire in the guages so i can tell my temp,rpm, and mph...i have the gsr ecu and the vx ecu...both of them will crank the car and appear to do the same exact thing..i'm not sure which one i should use though..keep in mind this is the 92-93 gsr motor..idk if that makes a difference in the swap but..i havent found anything on the wiring so..i dont know..but anyways i need help figuring out the guages and plus..i think there might be something wrong with the clutch on the ys1 transmission cause the arm comin out of the transmission is really really easy to move up and down and people have been tellin me it should have some resistance...i dont know what the deal with that is either...any info on this swap would be appreciated
