b18/16 mounts?
Discussion in 'Civic and del Sol - EG and EK' started by knownothing, Feb 26, 2009.
  1. knownothing
    knownothing never had a honda
    Tennessee
    will the b18/16 stock mounts bolt straight up to a 98 civic ex. or will i have to buy diffrent ones.
  2. BrutalB83
    Rochester Hills, MI
    In regards to this PM you sent me...
    ...you can bolt this in with factory mounts, but you need the correct ones. B-series mounts from a 99-00 Si or a 94-01 Integra should work. Or you can buy an aftermarket mount kit from Hasport or Innovative.
    In regards to the wiring, no, it won't just plug in and go. Do some research on OBD systems. You'll need to either convert the engine to run OBD2 or convert your car to run OBD1 (that's what the engine is). I would just get a conversion harness that will convert the car to OBD1 assuming you don't need to pass any type of yearly inspections that involves computer diagnostics...
