b18 build
Discussion in 'Engine Building' started by spencerhatchback, Nov 7, 2010.
  1. spencerhatchback
    spencerhatchback New Member
    pei canada
    hey its been awhile since i've been here i now am verry serious on building a b18 but just want to know what is best to make around 250-300 hp and still be daily driver
  2. rufio0306
    rufio0306 New Member
    St. Cloud, MN
    LS Vtec
  3. Matts96HB
    Matts96HB . Moderator VIP
    he's going to need more than lsvtec to make 250-300whp
    what b18 are we talking about building?
  4. spencerhatchback
    pei canada
    any under 2500 possibly a ls
  5. CAFROG
    CAFROG Honda Minion VIP
    NOR-CAL
    You got a motor/trans/ECU/shift linkage/axles/mounts yet? If not....$2500 wont go far in terms of any performance mod's.
    If you already have the swap, to "build" the LS motor (like you stated), you would not get even close to your goals. In order to get there after the build would be nitrous or turbo but you wouldn't have much cash left from your $2500 budget.
    Once again, if you have the swap, you can put together a new and used turbo system on an LS and get your goals....although the "reliability" of it would be in question...especially if you have a heavy foot.
    I say you raise your budget if you have the high horsepower goals and want reliability.
  6. 78civic
    78civic Junior Member
    NW MS, Y'all
    Not to poopoo on ya, but check the local Craigslist for some kid that wrecked his car with the swap already in it and make an offer..
    I think there was around 3 near me (memphis area)
    Or even the classifieds here..
    Hope you take lots of pics to post of your progress.
    E
  7. 96hondacivichatchdx
    96hondacivichatchdx New Member
    yea to properly "build" a b18 engine your probably talking around 20,000 dollars maybe more
  8. spencerhatchback
    pei canada
    well i ment 2500 for the motor im going to spend around 5or 6grand all together and there is a gsr for pretty cheap around me but it needs somthing on the block so i dont think ill go for it but the lsd tranny would be somthing i would like from that
  9. spencerhatchback
    pei canada
  10. spencerhatchback
    pei canada
  11. spencerhatchback
    pei canada
    might not be a gsr or ls but it would still work haha i doubt it would be 20000 sleeves pistons rods andfull skunk2 valve train with adjustable cam gears would run me around 3000, there is a guy that does bores around here for 150 bucks
  12. spencerhatchback
    pei canada
  13. spencerhatchback
    pei canada
    cheap but verry verry verry mint and if i did get it i have a 92 accord with the f22 that car needs
  14. CAFROG
    NOR-CAL
    Wow! Not trying to put a car into the stratosphere! A built B series is about $3000-4000 plus a Nice turbo set up $2500-4000. That amount of money will put any civic in the low elevens.....and faster.....especially if you do some of it yourself (leaves more money for tune time/axles/clutch)
    For $7000, you can definitely get 350whp and be reliable if your foot isn't filled with lead. But you would most likely need to shop around wisely.
  15. spencerhatchback
    pei canada
    somtimes my foot is lead haha when it needs to be
  16. jcook2125
    jcook2125 New Member
  17. Naturallyaspirated
    Naturallyaspirated New Member
    I know that bigger cams boring the block with a dip would get 50 hp alone plus a type r head is same price and 15 more then gsr. Just those three things take a 140 ls to 215-220 hp alone that is done for about 1000.
  18. Briansol
    Breaking 240 whp in a b-series all motor is basically impossible to do on a budget. A buddy had about 20 grand into his block with ITB's and the whole 9 and only did about 254 whp.
    If you want near 300, you need boost.
  19. SlushboxTeggy
    New Jersey
    B, you missed something about this thread....
