so i had a cut engine harness so i replaced it with another harness outta si as far as i can see everything is hooked up all the fuses are good but still no fire and the ecu ground is hooked up
it ran fine before i shut it off and no i didnt mess with the dizzy after i shut it off but it has a b18 mpfi and yes it is a dx but it will work an si engine harness is what i took out of it
The thing is I was always told that your engine harness has to match your interior harness. so I think you would have to get another dx harness and either convert that to mpfi or buy an already converted harness
