b18 in eg
Discussion in 'HYBRID -> EG-EK / DC' started by cbsupra875, Apr 10, 2011.
  1. cbsupra875
    cbsupra875 New Member
    im new to honda's i was thinking about swapping a b18 in a stock eg coupe not sure if i want a gsr or a type r. i was wondering what would be needed to do the swap
  2. jgpoirier
    jgpoirier New Member
    Axles, ECU, Tranmission, Wiring harness(dont do what i did with a cx harness and attempt to make it work, it will work with extending some wires but im to lazy to solder my splices), Shift Linkage, Throttle cable, rear tranny bracket from DC, drivers side motor mount also from a DC.
  3. cbsupra875
    the main thing im worried about is the harness. im getting a jdm motor so i figure the harness it comes with is gonna be too short. whats the easiest harness to use
  4. dilbeckskate
    dilbeckskate infamous
    Kennesaw Ga
    dude there are hundreds if not thousands of threads posted allready explaining EVERYTHING !!! use the search bar, and no dude the harness is plenty long, if the jdm harnesses were 2 short dont you think you would have read somthing abt it allready ?
  5. josh_crewdson@y
    josh_crewdson@y New Member
    nova
    Just use your stock harness and add/extend wires where needed. If it's an ex, you'll just need to add knock sensor and (iab for gsr) wiring. You might have to extend a few sensor wires.
