ok, I've read every b18 thread and can not find a definitive answer to this question. I have a 91 jdm crx with a dohc ZC in it, which is obdo. I want to put a b18b1 out of a 94-95 teg in it, which is obd1. I know you can buy the conversion harness, I know I need a cable tranny, what I want to know is if I use my crx injectors, put a b18 "OBDO" distributor on it and use a "OBDO" ecu, the alternator of my crx, will this be plug and play like a 90-91 b18a or are the other things I would need to change, like sensors or vacuum lines. If not possible with the 94-95, can it be done with the 92-93 b18a1. Thanks
