B18 parts, pistons, rods, ls blocks, clutch, y8 engine, manifolds cluster
Mr JDM
b18b1 block- std bore. freshlly honed, hot tanked, beaded- $400
b18b1 block- .20 over bore, ACL race bearings (crank installed)- $400
ls head OBD1- complete meaning everything! asking $200
d16y8 block- complete bottom end, not together but clean- $100
d16y8 head- complete minus IM dizzy and vtec solenoid- $75
D series valve cover- $30
LS valve cover stripped- $40
LS intake manifold. all sensors with gsr TB. OBD1- $60
Stock clutch and pressure plate- $30
LS pistons and Rods- Fresh and measured. $75
94 Teg cluster- $50
Ls Dizzy (works perfect)- $75
B18b1/a1 exhaust manifold $30
B18b1/a1 stock downpipe- $25 includes sensor
AC Unit. (everything) $50
d16z6/y8 exhaust mani $25
I WILL part out engines. Pm me for email or leave a message on the page. i have a picture of everything and i have vouches
yes the dizzy is oem.. all prices are listed above ^^^
would you be willing to ship the d16y8 block. I'am interested please let me know.
I'm from southern pa
Interested in some of the stuff youve got for sale
do you still have the d16 block and the ls pistons and rods for sale?
Hey im new here but i have a 98 b18b1 from japan was wondering do i need a specific computer from japan or can i just use a normal b18b1 comp or something better that just clips in?? going into a 98 civic dx coupe.. and do I need to swap all exhaust also? dx has that manifold with cat right there and its way bigger diameter looks like, will a normal 98 acura exhaust fit on all exhaust hangers properly??
first off do not post in another members thread asking a question that has nothing to do with the thread. second off your b18b1 was most likely from an integra ls. do some reasearch considering you know nothing. ill help you by saying you need an obd2 p75 USDM ecu just because your new
i want the d16y8 head, is it still available.. how much wld it b for shipping to los angeles ca?
i am a nood can you please tell me what a dizzy is and how much it costs to buy one?
i am going to do a mini me swap, so what all will i need.. i have a d16a6
dizzy = distributor
