b18 rebuild turbo
Discussion in 'Engine Building' started by DEAFKID15, Apr 24, 2008.
  1. DEAFKID15
    DEAFKID15 New Member
    i am getting this b18 block and everything is there but i'm gonna go turbo with a b16 head. so should i change the rings and what eles should i change. what size head gasket should i go with i just want to push 10 psi safely any tips will be good
    thanks guys
  2. 92civicb18b1
    92civicb18b1 The Trisexual
    This 10 psi is irrelevant. You need a power goal, it doesn't matter if it takes 2o psi to get there.
    You're just one of the 50 people a week who ask this question and don't know much about FI, and it's ok, you just need to read more.
    First off, research, it's not as easy as taking the LS head off and putting the b16 head on, there are many more steps in between
    Secondly, what is this car going to be used for? Power goal? Budget?
  3. DEAFKID15
    well i have a b16a3 in my car right now. but i just don't want to have to go with differnt piston and sleving the block and spend a buch of money. i dont really have power goals just want to be in the low 13 in a 1/4 at lest and i know you have to buy a conversion for the oil line. i have done a little reseach but just don't know what a stock ls vtec with new rings and bearings can hold with a thicker head gasket
