b18 sawp??
intenseneal
What would need to be done to swap an OBD2 B18b1 into a 90-93 Integra with an OBD1 B18a1? I have the B18b1, trans, ecu, axles and harness. I want to convert the b1 to OBD1. Please help.
it can't be done. there is nothing on this website that will help.
:disgust1:
Yes it can. I found out what needs to be done to do this swap. Use all 93 mounts and cable trans. You can use the B18a1 intake mani and dizzy or swap the B18b1 bizzy and injector plugs onto the a1 harness. This info comes from Hasport.
