B18 Swap civic
Discussion in 'Civic and del Sol - EG and EK' started by beatle351, Jun 3, 2011.
  1. beatle351
    beatle351 New Member
    Just got my first civic '00 civic ex with a LS in it. replaced the motor mounts with polyurthene. Now looking to turbo it. question is what size injectors should I run. I was thinking 550cc and how much boost can I run on the LS stock? withot obviously blowing it to pieces?
  2. D16SiHatch
    D16SiHatch New Member
  3. egb19c
    egb19c New Member
    550cc injectors will be good for around 8-10lbs of boost from a common t3/t4 turbo. I'd recommend going with some precision or I.D. 1000cc so you have room to grow... Don't forget you will need a chipped ECU to run the larger injectors also..
