B18 swap debacle
Discussion in 'HYBRID -> ED-EF / DA' started by B18EFHatch, Nov 21, 2009.
  1. B18EFHatch
    B18EFHatch New Member
    Pittsburgh, PA
    Just bought an 89 hatch with a b18b automatic swap. OBD1. It seems like nothing else was done to the car in fact the guy tried to swap an auto tranny in it and failed. So its unfinished. I'm swapping to a B18a with a 5speed cable tranny. I'm just gonna run the motor stock with just an intake and exhaust. Should i change anything else? like the fuel pump?
    New to the Honda scene.
  2. dc231581
    dc231581 New Member
    seattle
    fuel pump is a must, the car will run with stock, but should upgrade
  3. BrutalB83
    Rochester Hills, MI
    Was there something wrong with the B18B? It's essentially the same motor as the B18A, but newer...
  4. 91civisedaner
    91civisedaner Senior Citizen
    oregon city or
    maybe he want to keep it obdo???:confused::confused:
  5. B18EFHatch
    Pittsburgh, PA
    yeah, i wanted to keep it all obd0 and i found someone willing to trade my a b18a for my b18b
  6. B18EFHatch
    Pittsburgh, PA
    Do you have any suggestions for pumps? I found a few walbro 255's for sale. seems to be a popular pump for hondas in general. I don't know much about it tho.
  7. GlassHeadlights
    Calgary, AB
    No need for fuel pump unless you're going turbo or supercharger.
  8. BrutalB83
    Rochester Hills, MI
    You can easily run the B18B as OBD0. You just need either a conversion harness or all the OBD0 accessories...
    :werd:
    The stocker will work just fine if you're not planning to build or boost...
  9. B18EFHatch
    Pittsburgh, PA
    Yeah, but he got an obd0 swap for an obd1 and i had an obd1 swap in an obd0. so its easier to trade.
