B18 Swap Hood Clearance Problems
Discussion in 'HYBRID -> ED-EF / DA' started by rextec, May 9, 2003.
  1. rextec
    rextec Member
    will a stock hood clear a b18b crx swap? if not what hoods will? i bought a fiber images sir style right when i did my swap to be sure, but im thinking of getting another kind.
  2. GSRCRXsi
    MD
    stock hood wont clear
  3. Civic_88ls
    Civic_88ls Senior Member
    everett, wasington
    stock hood will too clear. it wont clear with the gsr motor but with the ls motor it WILLL work. it clears on my car.
  4. legutki
    legutki Senior Member
    i just did a gsr swap and I just had to cut a little webbing from the stock hood and it works fine. use a dremel tool with a cutting wheel; it took me 30 sec.
  5. D See 2
    D See 2 Senior Member
    Baltimore, MD
    most aftermarket hoods should work... or just modify yours so it fits.
  6. Slo86GT
    Slo86GT Super Moderator
    Memphis - Hellhole of the South
    LS's have a smaller head/valve cover that allows it to drop into an ED chassis.
    The GSR and Type R blocks are 9 mm taller than the b16a.
  7. Civic_88ls
    everett, wasington
    again, the ls will fit without any problems....
  8. rextec
    rextec Member
