b18 turbo rebuild
ok ok. but as for the boost. if i get it sleaved i could do 10psi with p30 pistons right? would my stock botom end still hold this relably?
you know what, I'm not sure due to the raised compression it would raise the horsepower of the engine, and LS bottom ends can only take about 275hp, so it would be close/iffy, you would need a really good tune to make it work.
you should make a new post about it. in either the forced induction forum or the engine building forum.
