spencerhatchback
hey looking for suggestions on b18 and turbo parts to make a 250 hp dd any suggestions plz haha.^_^
wow didnt know thats what the psi ment i just thought it was how much boost in psi u was runnin through... i agree bro, just sayn what i was running to give an example lolpsi is just a number that yields xxx HP.
stock engine should see no more than 250whp, and that is given that the engine has been WELL maintained, and has fairly low miles.
if your engine is tired, leaking oil, sounds sloppy, or has low compression, dont even consider a turbo setup without a rebuild
to answer your question, you can easily do a junkyard setup and make 200whp. used mitsu parts are cheap. do some searching aroud, youll find what you need.
it is a measure of pressure. people take it too far sometimes though. the amount of boost it takes to get different engines to a power level varies too greatly to just stamp a pressure on a certain power level, wouldnt you say?
haha yes, im learning as wellyeah ur right bro, i jus was givin an example of how he could cheaply do it lol and what ive heard is too much psi for stock .. i learnin stuff everyday lol ...
haha well im trying to keep the budget below 3000$ or so, well i was thinking of getting the mottor a port and polish and bossibly a small bore and try to get some pistons for it hopefully keeping that part under 1000, and probly the rest on a turbo kit and when i get to the dyno tuner i will get it pute together there or befor i go,,,, also i would have to drive the car there so i dont know if i could put the kit on and go or just do it there
