B18a/b Question
Discussion in 'Engine Building' started by pjecthatch, Feb 28, 2003.
  1. pjecthatch
    pjecthatch Junior Member
    whats the difference between the ls b18a in the 90-93 models and the b in the 94-2000 models? also does vtec matter when you're going to run a turbo?
  2. MaaseyRacer
    MaaseyRacer Senior Member
    San Francisco, Ca.
    The b18a was in the 90-93 integras, it was obd-0, and it had a cable activated clutch
    The b18b was in the 94-95 integras, it was obd-1, and it had a hydrolic activated clutch
    The b18b that was produced from 96-2001 was obd-2 and had the hydrolic activated clutch
  3. pjecthatch
    what kind of block work should be done to a b18b with turbo coming in future not sure how much boost. any suggestions? what kind of cr can be run if i want it to be a daily driver? but i also want it to be able to represent at the track. thanks for any info
  4. saturn_boy96
    saturn_boy96 88 C1V1C 53D4N DR1V3R
    Sheridan, WY
    depends, are you trying to represent against neons or vipers?
  5. pjecthatch
    if possible vipers
  6. NoJokE
    NoJokE Senior Member
    Vipers?!? :p Try some McLarens :D
  7. pjecthatch
    so what kind of block work am i looking at here? what kind of cr should i run?
  8. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    This is not entirely correct. The 90-91 B18A1 was OBD0 and uses a smaller clutch disc/flywheel than the other B series engines, it is also the least powerful of the 1.8l non VTEC engines.
    The 92-93 B18A1 was OBD1 and uses the same clutch/flywheel as all other B series engines. It is more powerful than the 90-91 engine, but less than the 94+ B18B.
    The transmissions that came on the B18A are all cable actuated clutches, the transmissions that came on the B18B are all hydraulically acutated.
