B BCDelSol Junior Member Oct 19, 2003 #1 Can u put in a b18a/b engine block straight into a Del Sol S using the same tranny, ecu, wire harness, etc? or do u need the complete swap?
P posol RETIRED Oct 20, 2003 #2 d-series trannys will not work on b-series block, and vice versa. the complete swap is generally needed, although SOME few things can be re-used.
