B18a crx won't spark
Discussion in 'HYBRID -> ED-EF / DA' started by RPMSUNLEASHEDHOUSTON, May 28, 2009.
  1. RPMSUNLEASHEDHOUSTON
    RPMSUNLEASHEDHOUSTON New Member
    Houston, TX
    Hey guys I'm James. I'm part of a LOW budget race team, we bought a crx with a b18a swap. That is honestly all we know a bout it. We got it from a land lord that foreclosed on a performance shop and he knew nothing about it so yeah.
    OK the problems be, that the spark plugs aren't sparkin. we bought a new dizzy b/c the old one was crap, but the coil isn't getting power.
    I got pics but I'm new so yeah. I'll try and figure that out
    Any and all help is greatly appreciated. We're just a bunch of highschoolers so we dont everything there is to know about anything.:)
  2. jlicrx
    jlicrx Senior Member
    Colorado Springs
    need more info:
    what model is the CRX (DX, Si or HF)?
    what ECU is in the car? ECU will have a sticker on the side with model number like: 37820-PR4-A00 - ECU is located in the passenger side footwell
    when you turn the ignition "on", does the Check engine light come on for 2 seconds and then go off, or does it stay on?
    is the car getting fuel? when you turn the ignition "on", can you hear the fuel pump running?
  3. lilsicsol
    lilsicsol i lOve my Ef sedaN..
    brooklyn...
    X2..^^^
  4. RPMSUNLEASHEDHOUSTON
    Houston, TX
    Well like I said we know almost nothing about it. The ECU code is 3782-PM6-A09
    The car is gettting fuel. We can hear the fuel pump, and the car has gas. When we pull the plugs to check the spark we can smell the gas.
  5. RPMSUNLEASHEDHOUSTON
    Houston, TX
    Oh and it has no badges so I can only assume that it is a DX
  6. Goldigginghatch
    Goldigginghatch New Member
    Bo$ton
    Its the ECU. The one your using is for crx si. What year motor is the b18a if its 1 90-91 your going to need a pr4 ecu. Hope that helps.
  7. RPMSUNLEASHEDHOUSTON
    Houston, TX
    thanks, we're still wandring wether or not we're going to keep it
