B18a into 90 crxsi
Discussion in 'HYBRID -> ED-EF / DA' started by dochvtecturbocrx88, May 18, 2004.
  1. dochvtecturbocrx88
    dochvtecturbocrx88 Junior Member
    ok my brother has a 90 crx si and were about to put the motor in i was just wondering if there is any wiring to do fo the B18a? Thanks!
  2. brian11to1
    brian11to1 Senior Member
    since hte car is already wired for MPFI I dont think there is. just use hte Si harness.
  3. erebunicrx
    erebunicrx my name is Dale
    Bristol ct
    :werd: im doing the same swap.
  4. 4drcivicb18a
    4drcivicb18a Member
    philly, PA
    It depends if the b18a1 is a 90-91 or 92-93 if its a 92-93 you have to change to 90-91distributor, 90-91injectors, 90-91 ecu cause their obdo 92-93 b18a1 is obd1 90 crx si is obd0 and use the crx wiring harness its way easier
  5. CESARSPINS
    CESARSPINS New Member
    I Have A 1996 B18b1 Going Into A Crx!!!!!what Will I Need!!!!!!!!
  6. nikozai
    nikozai New Member
    A. Convert to a OBD1 ECU, still using everything on the OBD2 engine. Alot has to be changed.
    B. Convert to a OBD2 ECU. Same deal.
    C. Changed the B18b electronics (dizzy/ECU) to OBD0.
    All the wiring is done using the original engine harness from your car and can be done for you by Rywire.com. We're also your source for the ECU jumpers that are necessary if you choose to modify the engine harness yourself.
    Good luck, talk to you soon ~ Peter
  7. CESARSPINS
    Will I Be Using The Obd 2 Ecu???????
  8. ryangt
    ryangt Senior Member
    man thats over complicated, get a 91-92 LS motor for it, drops right in (literally) and i only had to extend the O2 sensor wire and wire the radiator fan to a switch and add a aftermarket temp gauge, since theres no provision for it in the hf harness with a b18a engine
