b18a into 90 hatch dx
Discussion in 'HYBRID -> ED-EF / DA' started by vtecdaddy, Oct 10, 2005.
  1. vtecdaddy
    vtecdaddy Junior Member
    i have a obd0 b18a with ecu and tranny, i already have the motor mounts , but i was looking at the 1.5 motor still in the hatch and theres no injector plugs and it looks like its carberated. Do i have to get a crx si harness or whats the deal ,also what do i need to make the axles fit?
  2. tylonalsnifnfool
    tylonalsnifnfool Senior Member
    ny
    You've got DPFI (dual port fuel injection). My old CRX was a Dx. After my first attempt at a MPFI conversion I gave up. It can be done but it takes alot of knowledge.
  3. vtecdaddy
    im not big into wiring , so if i get a 88-91 hatch si or crx si everything will jus plug up right????
  4. brian11to1
    brian11to1 Senior Member
    no.
    use your stock DX harness, wire for MPFI and extend the TPS 6" as well as switch the two outter wires.
