depending on your ECU, you can run the knock wire from the ecu to a ground. but that has only worked half the time i've seen it done. Sometimes the car runs fine, sometimes the timing gets retarded even without throwing a CEL. i'd just get a chipped ecu like formby said, but that's IMO.
