b18a perfect fit?
my friend has a 91 crx i have a b18a out of my wrecked 91 teg. it should be basic put in besides axles, linkage and motor mounts rite?
ECU, probably an obd conversion harness is needed in there and tranny.
You will also need to address the fuel system wiring if the car is NOT an SI. If it is then you are on easy street; otherwise you will have to convert the car to multi port injection. Search is your friend.
[post=382927]Quoted post[/post]​
they're both obd0 and non-vtec, no conversion harness is needed.
correct, no conv. harness needed. you could run on the si ecu but not at full potential. everything schould be right there in the totaled car except the mounts and linkage unless its not an si or hf like projectxspeed just said.
Originally posted by revolution8k+Aug 28 2004, 04:28 PM-->
Originally posted by kylemarhx@Aug 28 2004, 02:38 AM
revolution8k
[post=382964]Quoted post[/post]​
You're right, I looked at the wrong info in the reference section. :doh:
[post=383110]Quoted post[/post]​
You had to look in the reference section for that?
Another thing thyat was not mentioned was the fact that if it an hf, you will have to swap the front hub assemblies with the integra's or get some dx or si hubs. I'd just use the integra's.
Originally posted by MikeBergy+Aug 29 2004, 03:45 AM-->
revolution8k
[post=383225]Quoted post[/post]​
You have everything memorized? I have other things to remember besides what motor is where and whatnot. Just keep taking stabs....yeah..
revolution8k
[post=383291]Quoted post[/post]​
Whoa man, I was just playing, my bad, don't take it personally. I just remember it like this.
88-91 obd0
92-95 obd1
96-present obd2
It's the same for all makes of cars too, and no I don't have everything memorized, especially not honda paint codes and names :p
Well, to be more specific, its:
88-91 obd0, 92-95 obd1
civics:
96-98 = 2a
99+ = 2b
tegs
96-99 = 2a
00+ = 2b
But all I did was look at the ref section real quick and I think I looked at the b18a, and then traced over into a different motors obd level where i saw 1 or 2. ;)
if your driving as a daily driver and dont like a loud ride from the engine vibration i would not go with them. i have them and love them but some people dont like how stiff they are. just my .02
