b18a swap into 5th gen civic
93jdmcivic
im planning on swapping a b18a into mah ride. i knoe wat im goin to get but the problem dat im concern about is the wires..i think the b18a is obd and my car is obd 1 is der a harness out there that i can use..need a lil help.. :(
First go back to english calss.
then, get all the brackets from the b18a1, and get all the mounts from a 94-95 integra. and get an obd1 intake manifold from a 92-95 ls motor. get the obd1 throttle body too. you can use your stock wiring harness.
hope that helps.
you'll need a hydro tranny too along with 94-2000 teg shiftlinkage.
i know what you need cause thats the swap i'm doing now.
later.
:werd:
typing like a fucking retard will get you nowhere fast
putting that engine in the car is illegal in most places (engine must be from the same year or newer than the chasis of the vehicle)
basicly dont bother with it ... it will cost you far more in the end than getting the correct engine would have in the first place
