B18a swap trouble
neurovox
I am putting a ls vtec into a 94 civic and haveing motor mount problems.
B18a block, jdm cable tranny.
I am useing top left and right mount from a b18a but the back t-brace will not line up.
I have tried the b18a, civic, and b18b t-brace. what am I doing wrong? I Know the tranny mount needs the b18a brace and the passangers side mount needs the b18a to line up with the angle pattern of the support bracket off the block. So which T-bace do I use? Anyone know. Thanks,Kevin
Just get the front tranny mount from energy suspension and forget about the rear one. Its a biznatch, even if its the right one. three mounts is all you should need.
Do you mean the insert or are they makeing actual mount now? I have the top left and right hooked up. What would be the 3rd?
