B18A Swap
Discussion in 'HYBRID -> EG-EK / DC' started by 98DoHcWarrior, Apr 3, 2004.
  1. 98DoHcWarrior
    98DoHcWarrior Junior Member
    IM trying to put a B18A in my 98 honda civic can someone explain the process and the things i need to change and what motor mounts do i need and what not, hopefully somneone can help me
  2. E_SolSi
    dont use a B18A
    that is quite possibly the worst idea ever
    get an OBD-2 B18B
  3. highlife
    highlife Senior Member
    swaping a B18a into a Ek is not worth the time and effort.
    get a b18b or b18C
  4. Slammed90Lude
    Slammed90Lude Senior Member
    milford, PA
    :concur: x 2
    that motor is def. not worth the work it would take to swap it into an OBD II car- go to hmotorsonline and order a b18b or b18c1- you'll thank us later
  5. brian11to1
    brian11to1 Senior Member
    :concur: x3.
    Someone tell him why it isnt worth... Ok I will...
    B18A1's were only produced in two OBD forms, OBD-0 and 1. The B18B1 were produced in 3, OBD-1 (94-95), 2A (96-98) and 2B (98+). So with this said since your car is a 98 its OBD2A, just get a 98 or newer Integra motor, or for 900 from hmotors you can get a CRV motor which will go directly in via some help form a mount kit and shift linkage mod. If I missed anything, let me know.
  6. Slammed90Lude
    milford, PA
    well the crv motor swap will also require a hydraulic trans that isn't made for AWD- but otherwise :thumbsup:
  7. 98DoHcWarrior
    well see the problem is i dont have the money for a B18b i blem my d series and i got the b series for free from my little brothers integra and i have to put it in bc ive already starrted is there anyone who could just help me in how to get it to work i have no prblem with the work i just need to know how exactlly tomake it work
  8. brian11to1
    ask around about the hydro tranny. it will save you a lot of headaches.
  9. 98DoHcWarrior
    Ok thanks anything else is should know, that would help me out alot, i wish i had the moiney for another motor but i kinda have to workj with what i got...
