Ok... CRX Si is getting a B18A. I have it already. The swap came with wiring harness/ECU. Will the ECU plug right in? How about the engine wiring harness? will that plug right in to the wires that go to the ECU?? Or will I have to splice wires?
I also have questions about Vacuum routing. Is there any diagrams/good pictures of someone else's B-series swap available? Will I be able to use the same MAP sensor? I also saw vacuum plugs or something mounted to the transmission. Where do those go? thanks guys...
