crxb18aturbo
I am putting together a b18a turbo setup, i am putting on a thick head gasket, ARP head and rod bolts. I would like to run 8-10 psi. Should I be using a T25 or T3/T4 turbo? On each what fuel mods do i need to make? Are bigger injectors a must, will a decent FMU do the trick? Will the stock pump push enough (91 CRX Si)? Will an MSD 6AL be a sufficent ignition. Any info on the subject would be helpful. I am new to the turbo game and in need of info.
