B18a1 Bearings
TitanDriver
Fellas, I'm sorry for such a noobish question, but I need in layman terms the bearings I need.
Okay, the FSM is confusing the hell out of me, first it says check the block (BCCBB) then the crank says B2, 2,B,2,B,2,B,2. So if I read that right. then the main bearings would be:
B2 - yellow
C2 - green
C2 - green
B2 - yellow
B2 - yellow
Does that sound right or what's on the block doesn't matter? What about the rods then?
Thanks
I'm not over thinking it, just had to double check. I understand that there's a possibility that the bearings could be different for both rods and main bearings. Just needed a second set of eyes to make sure I got that right.. Thanks.
Thanks, that's page is clearer that the FSM I got. Thanks. I got it now..
Looks like the same thing to me, just with less information so there's far less of a chance of over-thinking. :)
Okay, just needed it broken down in simple terms, so can you stop busting my balls now?:g:
So here's what I got:
block: BCCBB
Crank: B2, 2,B,2,B,2,B,2
rods: 4,3,4,4
So that means (Please correct me if wrong):
Main bearings:
yellow, green, green, yellow, yellow
Rod bearings:
brown, green, brown, brown.
