B18a1 help
Discussion in 'Civic and CRX - EF' started by MTM, Aug 22, 2010.
  1. MTM
    MTM New Member
    Well i just got a swap on my 91 honda civic dx and the engine is overheats
    could it be that i only have one fan on it?or what please help
  2. D16SiHatch
    D16SiHatch New Member
    did you properly bleed the air out? have you replaced the thermostat?
    the one fan is more than enough, that's not your issue.
  3. MTM
    MTM New Member
    yea i did replace it and bleed it out
    and well the radiator is stock from the ef could it be that?
  4. D16SiHatch
    not likely, not unless it somehow became clogged. which seems unlikely
    honda's are notorious for being overcooled and the ef radiator is more than capable of keeping a b18 at the proper temp.
  5. MTM
    MTM New Member
    thats weird like now its fine...
    hey i have another question my cluster on my 91 ef the speedometer isnt working like everything works fine the gas and temp do u know what can b the problem?
  6. D16SiHatch
    cable might have popped out of the back of the cluster or the transmission. if not that then the cable might have broken internally
  7. money b
    money b New Member
    mine does the same.. manifold sits to close to it does it when it sits still for a while right? wire a toggle switch to it turn it on when stopped thats what i did.. no problems now.
  8. D16SiHatch
    a toggle switch for a fan that should come on automatically is ghetto. don't be lazy and fix the problem instead of bypassing it
  9. money b
    money b New Member
    im also wireing my sensors straight to the computer.. ghetto.. oh well.
