if the car is a DX and not STD, you don't need to swap hubs - you need the B-series cable transmission (like the stock LS) and 90-93 integra axles, mounts, ECU and shift linkage - you will also need to do the DPFI to MPFI wiring changes using your DX engine harness
Originally posted by EFB18A1@Jan 6 2004, 12:50 AM
the guy that's helping me do the swap said I would need the Si hubs and I'm not sure if I need the Si tranny.
