B18a1 in 90 hatch idle problems
fixed4 life
I just swapped a B18a1 into my 90 hatch. When i turn it on in the mornings it idles high 3000 rpms. After it warms up it idles up and down between 1000 and 2000 rpms i am using a 91 integra ecu. The ecu is not throwing any codes so unsure what it is i have checked my vaccum lines they seem to be ok. Any help would be appreciated.
I would check out your idle air control valve. It is located on your intake manifold. I would take it off and make sure the screen on it is clean, and that it is functioning correctly.
either throttle body is shot and is leaking air out enourmously or ur heating core is bad go have them checked out i had the same problem swapping a b18a1 a while ago but i had a bad Throttle body lawl...but pay someone to check it out or if you know enough you do it...
