b18a1 in 92-95 civic
dorian
Hi!
I have a 95 civic ex and 93 integra gs(b18a1) whole car wrecked bad.I what do swap the integra motor into the civic.What will take to do that?
Any comments will be appreciated!
dorian454@yahoo.com
Ok, I have got my engine in my Hatch already. Here is what you will want to get.
94+ back tranny bracket about $70 from dealer.
94+ shift linkage other linkages can be used but require cutting. I don't reccomend doing this
You will also need to take the speedo sensor out of the tranny of the teg and replace it with your speedo sensor. It is just 2 bolts but the teg sensor is not electric like the civic sensor. Good thing is they are a direct replacement. For the radiator hoses I just used the ones that were there and cut them to size but you can use del sol hoses. Remmeber mark everything as you take it apart. I forgot to do this and had a bad time hooking it all back up. Let me know if I can be of more help.
Mark
