b18a1 in a crx help
daveholiday
Do work
so I'm going with putting a b18 in the crx. for anyone who has done this, I know that I will need:
b18 motor
shift linkage
front axles
but what about fuel injectors, ecu and whatknot? if I do need a teg ecu, will it plug right into my current harness?
its goin in a 1990 crx si, currently have the d16a6
b18 motor
shift linkage
front axles
is the B18 engine OBD0 (determines what all you will need)
you also need B-series transmission, aftermarket mount kit and Integra PR4 ECU (will plug right in to the harness) - you need to use the D16A6 Si engine harness on the B18
i believe its obd0 but i could be wrong
as far as the tranny, just one off a 92 teg (year the motor came out of) along with the shift linkage and axles, correct?
and the d16a6 engine harness will plug right into the b18 one?
the PR4 ecu is the ecu out of say a gs?
wont a hondata ecu work?!? or am i smokin something? cus im lookin for b18c1 in my rex obd2 and i was told hondata is the shiiiat?
