b18a1 in crx si
Discussion in 'HYBRID -> ED-EF / DA' started by INJEN78, Dec 6, 2008.
  1. INJEN78
    INJEN78 HS LEGEND
    OHIO
    cant get it to kick on,have fuel,spark,checked the timing,all the marks lineup,(do i have to check anything with compression stroke?)the motor ran in my civic hatch,now it wont run in te crx,redid all the gorunds,just wont start,itll turn over nice though:D
  2. t3t4delsol
    t3t4delsol New Member
    York, Pa
    can you turn the crank? meaning using a breaker bar and manually turn the motor?
    also how old is the gas?
  3. INJEN78
    INJEN78 HS LEGEND
    OHIO
    yea its all fine,just wont turn over,the gas is a little old,but that shouldnt cause it to not start
  4. t3t4delsol
    York, Pa
    have you checked your fuel pressure? fuel filter?
    If you think your spark is good, get a can of ether, remove the intake and have a buddy start the car while you spray the ether in the thottle body.
  5. INJEN78
    INJEN78 HS LEGEND
    OHIO
    ive got pressure,and i will check the filter,
  6. George777
    George777 ^^ Likes Bewbies
    With your mom
    Worked for my car. Worth a try. And if it doesn't start the car, it will give you the opportunity to use the rest of the can as a torch and burn stuff to take out your frustration. It's a win-win!
