JODYG35950
I have a 1988 crx si car with 88-91 body and frame, but has 87 model wiring in it. What do I need to do to make this swap work? I made my own ECU harness with the plugs out of the teg i got the motor from. There are about 9 wires from the original ecu plugs that do not go directly to the motor, so i need to find out where the actually go or if there is an easier way to do this.
