b18a1 into 88 ef
Discussion in 'Civic and CRX - EF' started by akshn1, Apr 3, 2009.
  1. akshn1
    akshn1 New Member
    San Diego, CALIFORNIA
    i just bought a ls swap...i have a 88 ef...has anyone done this swap before? how hard was it...and has anyone got this car reffed with this motor....NEED INFO!!!
  2. efhondakid
    Akron-Canton, Ohio
    Its a pretty basic swap depending on the trim level of your car, search a little and you will find a ton of info on this swap.
  3. INJEN78
    INJEN78 HS LEGEND
    OHIO
    word.pretty easy,1 step up from direct replacement.you will need
    mounts(i have a set for sale if interested)
    axles
    ecu
    shiftlinkage
    fluids
    and the accessories for the motor
  4. akshn1
    akshn1 New Member
    i bought the full swap for $750 off a friend...b18a1..AVID mounts..b16 tranny re-geared to have 4,5th ls gear..lightened flywheel..shift linkage with short shifter................how hard is the swap? does it drop right in?
  5. INJEN78
    INJEN78 HS LEGEND
    OHIO
    wow you got a hell of a deal..it doesnt exactly drop right in..you have to dent the drivers frame rail to clear the alt. and i had to cut the front mount bracket off the front crossmember,you also have to dent the lip down on the rear crossmember to clear the tranny bracket
  6. Ryma
    Ryma Member
    Frommy understanding the only changes really you have to do with teh wiring is at the dizy.
  7. akshn1
    akshn1 New Member
    im gonna be dropping it in this week hopefully see how it comes out...ill post pics...
  8. 78civic
    78civic Junior Member
    NW MS, Y'all
    SO, howd it work out for you??
    I just picked up a 90 4dr and already have the LS parts (Gathering more info since the D15 just runs too wel to pull just now.)
    E
