B18A1 into 95 Hatch CX
95hatchcx
Member
I have a 95 hatchback CX with a OBD1 and a 91 Integra motor which
is OBD0. I have the drive axles, transmission, motor mounts and the
wiring. I was confused on how to do the swap. Can anyone help
me? I know it would make the swap easier if i bought a 92 distributor
and intake manifold with the wiring. What about the wiring harnesses?
and can i use the obd1 ecu if i swap the distributor and intake?
get an obd1 distributor, intake manifold, and wiring harness.
by 91 integra motor, i'm assuming you mean b16a, right? just get an obd1 p30.
if you use the obd1 harness, everything will plug into the motor and to the in-car harness.
you'll have to use an obd1 ecu unless you put an obd0 in-car harness in your car.
the motor is a b18A1 from a 91 integra, is there any good websites that
has good prices on distributors and intake manifolds for B18s with obd1?
