B18a1 Into A 92 Civic Hb How To?
Discussion in 'HYBRID -> EG-EK / DC' started by dwn2low, Mar 2, 2003.
  1. dwn2low
    dwn2low Senior Member
    Little Rock AR
    Hi,
    I have a 93 b18a1 and i'm droping it in my 92 Civic HB CX. Is there anywhere i can get a step by step how to. I have never swaped engines before but i am mechanicaly inclined. I was also told it is a fairly eazy swap. I have the hasport mounts already.
    Thanks
    Mark
  2. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Get a Helms and follow the instructions for removal and installation.It is really that easy.Did you get the cable clutch adapter from HAsport also?
  3. dwn2low
    Little Rock AR
    Yes i did get the cable clutch adaptor. I also have the haynes manual for both cars. I was told i need the axels and the shift linkage from the integra and i also need delsol radieator hoses. Is this true?
    Thanks
  4. xj0hnx
    C.C.TX.
    Any B series axles and 94+ B series shiftlinkage LS 94 upper hose and 94 delsol lower.The intermediate shaft will play apart in the axles selection though as the seals are different on the 90-93.
  5. dwn2low
    Little Rock AR
    So I do need an intermidiate shaft? If so it should be the same years as the axels right?
    Thanks alot.
  6. xj0hnx
    C.C.TX.
    Yes you need it,and yes it should be from the same year :D sorry I forgot to mention that.
  7. dwn2low
    Little Rock AR
    Thanks alot I realy appreciate it. The local shop around here wanted to charge me $1000 to put it in so instead I went and bought me a cherry Picker :) For $145 and decided to do it myself.
    Thank
    Mark :worthy:
