B18A1 into a OBD II 6th Gen Civic
SLOWHONDA
How do i wire up a obd II dx harness and and ls harness im doing a 93 b18a1 swap into my 96 dx can somebody help me out here
dooood.....
why not just spend like an extra 100 bucks and get an obd2 LS....shit even an obd1 is better than the obd0.
It's gonna cost you a lot more trying to get that damn thing to run. I'd convert that engine to obd2 spec (sensors, throttle body, intake manifold, distributor, injectors) and use your DX harness.
you'll also need a hydro transmission, clutch, flywheel, shiftlinkage, axles, and a WHOLE BUNCHa shit.
true, true. didn't see the year only b18a1.
but thats really beside the point, still not worth the money to convert to obd2 specs.
An obd2 to 1 conversion harness and the right obd1 ecu will work fine, other than maybe some small wiring. :ph34r:
